Rustyregal
 - Jun 7, 2012
So my car was running better than ever at around 20psi. Decided to add one of my last modifications an RJC downpipe. After installation I began to notice that no matter the pressure setting (15-25psi) when my boost would peak it would begin to fluctuate. With lower pressure the fluctuations were large with a variance of 4-5psi. When I moved up to 25psi it would peak then fluctuate 23-25-23-25-23-25 and so on. Also as an added side note it spools archaically slow until 10psi then comes in normally.
Now on to what troubleshooting I've done:
-Replaced all of my actuator lines and tywrapped
-pressure tested and leak down tested my actuator
-Installed an RJC boost controller
Will of the above with no change. Then I removed the downpipe and noticed that the puck rests WAY to one side of my watsegate port. Apon closer inspection it looks as though exhaust gasses are escaping at the bottom left of the port. The imprint on the puck shows how offset the contact patch is. I'm wondering if its able to put leverage on the edge enough to lift it and cause the fluctuations I'm seeing. Any ideas are welcome as I'm at the end of my rope. Has anyone ever encountered or heard of this?
