boost gauge install
moyersgn
Did a search on boost gauge install. Saw that hose needed to be placed on vacum. Can any one provide a pic of where this is and how its hooked up. Thanks.
Check out the hose that runs over to your charcoal cannister. It should have a small white check valve inline. That is a good place to tap into the line & install your T between the check valve & the engine.
~JM~
~JM~
Just make sure the T fitting from your boost gauge (assuming you are assembling from a new package) will fit this line. My Autometer gauge did not, so I had to go to the passenger side and tap into the hard plastic vacuum line coming off the steel line/vacuum block. In retrospect glad I did as I can hide the vacuum line neatly behind engine.
best place to tap is second from the front line on the tb vacuum block easy to hide the line no probleme
