Boost gauge vacuum line question
Danster
Senior Member
After fiddling around with the car yesterday, I noticed my boost gauge stopped working along with the stock gauge (dash panel). I checked out the car this morning and discovered a vacuum line broken. This line is the plastic one about 1/8 diameter in size and is connected from the passenger side firewall where the relays are located and the other end is connected to a T. Vacuum source is from the vacuum block the other side of the T goes to the boost gauge. It seems the vacuum line from the passenger side firewall was stock and there are other lines of the same size present in the car.
I was wondering if the plastic vacuum lines could be purchased from any auto parts or are these specfic to the TR's and can only be replaced by some vendors on this BB?
Dannyo
You can buy it at Pep Boys on a blister card. Look near the air shocks. Same stuff.
