SignUp Now!72firebird said:I took the hose that runs from the MAP to the hardling on the plenum and pulled that off and put it on one side of the T and then got a little bit of hose to run from the T to the hardline. Works well and I didn't have to cut anything. Plus it's set far enough back you can't really see the T.
bkoons said:The hardline is a plastic vacuum line that is used on newer cars. Your local Shuck or Autozone should have an assorment of the rubber boots to use with them, including T's and reducers. You just need to run a short section of new line from the original boot on either end and put in the appropriate T fitting between it and the original line. Or just use new vacuum hose.
Jan Larsson said:I know the feeling, I had a hard time just finding the T in this country ended up with a white T for 4mm hose (I think it was) painted it black got the rubber connector off some spare hose thing I had laying around used some super glue to stick it together ..... when I was in the US later I picked up some spare stuff for when I redo my engine bay this winter.
Anyway snapped some pictures of my install and also of the parts I bought, the nylon tubing kit I bought at Autozone (or possibly Kragan) found it in the "riser" department where they had some gauges and stuff.
Also the rubber connectors are avalible in the help section for differnt sizes I grabbed 2 different (or possibly a few more) as I could not remember the size of the T I used.
Anyway hope this helps and you can get everything together.
