boost gauge
Here's a pic of the front view of the intake I zoomed in if u can see in the center of the pic right behind the thermostat housing and to the right u see a black plug ... Well there should be a screw there in urs take out the screw and screw in the brass fitting and vacuum line from ur boost gauge there ... Hope that helps
mine's tapped into the line going to the fuel pressure regulator... it was like that when i got the car, and i figure it's as good a place as any since it will tell me what the regulator "sees"..
Or really any vacuum line as long as it is before the check valves
