boost peak gauge
ckmm
the $ money i could save
do they make a boost gauge that holds your highest boost per run or can you make one if so could use some help useing reg gauges no comps thanks
Go to Autozone or Advance Auto and buy an analog tire pressure gauge with the "hold" feature. Then cut off the piece that you put on the tire valve stem. Then connect the gauge to the intake manifold and you have a peak/hold boost gauge. Mount it in the passenger compartment or under the hood.
Conrad C.
cool
have u tried this i just want to see what peak boost is trying to set my rjc vavle right now trying to find out why my blms are low about 115 changed nothing but the turbo use to run at 128 all the time
Yes I have and it works GREAT! Cheap too.
Conrad C.
