Bottle warmer for propane?
You can just use ones intended for nitrous bottles.
Or one of the distributors for the Pro-Pain kits has them.
Thanks. Doing my install right now. Pretty cool out west at present and I'm going through some old propane threads that indicate bottle pressures drop with temps. Probably need the warmer all year long!
I would'nt doubt it,especially at night.From what I can tell you need at least 75 degrees outside without a warmer for it to be effective.The more you use it the colder it gets so I'd imagine after alot of back to back runs it will need some heat to bring the pressure back up.I have had my car up to 25 psi with no knock on some short 1/8th mile bursts,but I do need to get a warmer ASAP.I would like a low tank pressure warning system for this,seems to be all that is missing at this point besides enough radar freee open road.
Have you had to refill yet? I'm going with an "alternative" mount for the bottle beside the spare. I think I could fit a 20 pound bottle in. Will start with the 5 and see what happens.
