Speedometer still not right, cruise inop too.
First of all, this was an awesome thread and really helped me with my recent installation.  I have Performance Industries GNX 'style' dash, in the car and working for years. Haven't done anything to anything remotely close to the dash or the speedometer or the vss.  Speedometer started going wacky on me few weeks back, working when cold, then after driving a few minutes, fluctuating, more and more, then wildly, then indicating zero (and it wasn't my driving
).  Oh yeah...and the scanmaster mph was jacked up similarly.  I only have a lower speedometer cable which runs from the tranny to the vss next to the powermaster, from there it's just a wire (pair) that goes into the dash and electic VDO speedometer.  I started by lubing the lower cable - no difference.  I replaced the lower cable - no difference.  Took a guess that it might be the VSS.  So I decided to try a new one.  So I purchased the three CASPER's boxes reference by so many (102046 VSS CONVERTER MODULE, 102007 VDO TACH CONVERTER MODULE (for the cruise control signal), 102045 VSS VDO Sender Dead End)...and spent the weekend rewiring.
Wired it in accordance with:
http://www.installationinstructions.com/102046.pdf except that I didn't run black and red to the speedometer (because it is already powered and grounded as part of the wiring in my GNX cluster).
 Now, after a test run...I have just minor, but annoying fluctuations on the speedometer (+/- 7mph) and rock steady mph on the scanmaster....and my cruise doesn't work.  So now I'm guessing that my speedometer is bad?   Not sure why cruise isn't working.  Any ideas?
Also, I assume, though it doesn't say explicitly in the wiring directions, that I can use the red and the black that used to connect the speed buffer (green box) to source the new boxes. (i.e. where the wiring diagram says "connect to switched +12Vdc").
whew!  appreciate any suggestions.
Matt
