I have a set of stock control arms that have been welded up with the H&R boxing kit. This was done by a professional welding shop. The lower arms have H&R Poly bushings with grease fittings installed. They have always been lubed with energy suspension grease. The upper control arms had new GM bushings installed. I had them bead blasted clean and then I painted them with a POR 15 paint. I am changing my setup so I no longer need these. I put fresh rubber bushings in the upper arms after reading about all the problems with going full poly on the rear suspension.
I bought the sway bar in 2004 and I am pretty sure I got it from ATR before they went under. I am also including grade 8 bolts. Not the stainless junk they normally come with that strip or can not be torqued properly. I had the bar for a year or so before I put it on.
All of these components have been on the car for about 4 years, and a whopping 5000 miles.
I will sell everything for $250 plus shipping. $200 shipped if you have a set of clean stock rear upper and lower arms to send me. (Pics first please). Thanks!
