BR 2004Rs
quickt
I have built and ready to go. BR-2004R includes the following:
BR core
Billet forward drum (not harden welded stuff)
New Delco direct drum
Wide band
Dual feed direct with 8 clutches
Rollered rear section
3 clutch OD
Billet servo (my own)
Parallel decked pump halves
10 Vane pump (rotor, slide and vanes)
.500/.400 boost valves
billet anchor pin
Hi Psi regulator valves
Stage right trans brake
13 years of building HI Per 2004Rs
1 year warranty
$1895 shipped 48 states
Why run easy 11s when you can run low 10s for a couple hundred extra?
