braces, power antenna, chips,009s turbo.mount TTA
gn4u2c
Yes Its fast no you can't
I have a set of the monte carlo SS cradel braces $30.00 shipped
87 Antenna ,power antenna mast is in great shape motor runs perfect both directions plugs are great not cut.needs the basic rebuild kit avalible from brian at gbody parts. $25.00 shipped.
Reds 107(h) chip 009's $20.00 shipped
hypertec chip pt # 413 72 sn # 169,947 $15.00 shipped
ATR Pitbull hp137 r3 arb eo d304-2 $20.00 shipped
ALL 3 chips for $ 40.00 shipped !!
TTA factory replacement engine mount drivers side was on my car for maybe 1 month and I switched it out for hr mount. $15.00 shipped
ill take the cradle braces if these are the 3 under the engine and the 2 on the radiator support?
you got all them from me these are just the 2 in this pic below, I would think you have them now if not monday at the latest comming to you ups ground.
I'll take the 87 Antenna ,power antenna mast is in great shape motor runs perfect both directions plugs are great not cut.needs the basic rebuild kit avalible from brian at gbody parts. $25.00 shipped. Any idea how much the rebuild kit is & is it easy to rebuild? Thanks
Sounds good,by the way would you happen to have the Power Antenna Mast Mounting Bracket & Antenna Nut / Bezel (Black) to go with it too? Please let me know. Thanks
the lower mount is there what you see is what you get I somehow lost the upper bezel / nut just transfer yours over.
87 Antenna ,power antenna mast is in great shape motor runs perfect both directions plugs are great not cut.needs the basic rebuild kit available from brian at gbody parts. $25.00 shipped.
Still available? This antenna is from a TR right?
Thanks,
Guy
86GNTTYPE are you mailing payment ?? I do not see it in my paypal ?? its already in a box ready to go. Please make sure you sent payment to jasond1986gn@aol.com and I will get it out right away.
