bracket
USMC_Turbo6
Can someone tell me where does this bracket go.
Can't get rhe photos to upload.
Text it to me. I will PM you my number. If I don't know what it is, I will post it for you.
Got this one. For the hood struts:
This one I am embarrassed to admit I don't recognize. A sensor will slip under that little lip and a screw holds the sensor on, but I do not recognize it...
Dee,
Can't get a good pic on my phone but found this on a quick google search. Basically there is a ring/clamp that goes around your accumulator/dryer, then the clamped ends bolt to the one threaded tab on your bracket.
It mounts directly below the blower motor relay. I removed the wire loom clip and the relay so you could see the bracket. Nevermind the missing bolt on the bracket lol :cry:. Also my wiring is not in the factory location here as I wanted a little extra room for the harness and routed it slightly different. I have included the factory picture for wiring.
I was looking for a different picture and found this one. It shows that bracket perfectly lol.
