I replaced the powermaster, rear cylinders, and proportioning valve due to failing parts and maintenance. The rears are now 7/8"dia. I bench bled the master cylinder, I bled out all the wheels in sequence, I've bled the lines at the M/C, and prop valve. But the warning light still comes on everytime I release the pedal.
I've gone thru a gallon of brake fluid and it still sounds like bubbles are passing thru the prop valve. NO bubbles at the bleeders or anywhere else I open the system, WTF!
Anyone run into problems with larger wheel cylinders and the brass proportioning valve?
