Alright, I'll try to keep this short and sweet so noone will get bored:biggrin:
Pump went out, had rock hard pedal and brake light on whenever ignition was on. Replaced brake pump assembly (reman) about a year ago. I only drive it about once a month.
Since replacing the pump, the brake light comes on for about a second when braking and then goes away. It comes on every time you hit the pedal. It always goes off about a second later. If you hit the pedal very slowly it doesn't come on.
Did an accumulator bleed by pumping the pedal 10 times and no air in resevoir. Bled brakes at the caliper in front and at the drum in rear with wheels off, still have brake light coming on.
Unhooked brake switch on the frame under the car (don't know which one it is, saw it on wiring diagram) still have brake light. Unhooked the switch behind the resevoir beside accumulator ball and brake light did not come on.
I don't know if this means that switch is bad, or if something on that side of the brake system is bad. Unhooking it basically unhooks everything.
Any thoughts/ideas appreciated. The pedal feels fine and the car brakes well. I just can't get the brake light to go away and it makes me nervous.
Thanks-D
Thanks-D
