The 25amp A/C fuse powers the PM drive motor relay. If the relay stops working because of no power, the motor won't run and you won't have brake pressure.
The 30amp Dome/Ctsy light fuse powers the motor itself.
So be sure which fuse is blowing out.
If the A/C fuse is blown, you may have a bad relay. It also may depend on what else that fuse feeds. I don't have a complete schematic, only the PM manual. The problem may be somewhere else besides the brake system.
HTH
