Brake Light
richburke03
My brake light flashes for a split second when I hit the brakes sometimes. The brakes work perfectly fine no mushy pedal or anything like that. The only problem I ever had is last year I was out for a ride and it seemed like my driver side caliper was sticking when I came to a complete stop, but it only did it one day and hasn't done it again.
I had the same exact issue , had to replace the accumulator bowl...
Symptoms point to accumulator bowl.
DO NOT drive the car again until the problem is resolved lest you cause more damage.
Definite first sign of a dying accumulator - run the diagnostics to be sure
Then give the system a good bleeding
