SignUp Now!Originally posted by Red Regal T
Could be a defective turn signal switch that runs through your column.
Originally posted by TurboJim
Hmmm, not to be a wise guy, but are you overweight? I ask this because overweight people generally flip the tilt up to get out and down to drive, usually causing those wires tio break faster. Soon it will be the wiper wires. Might wanna pull both harnesses thru to check and make sure the wiper one isnt gonna break soon, while you have the wheel etc off to change the t/signal switch.
I see it all the time on GM cars. And sorry for the personal question, its just what I have seen over the years.
The white wire out of the brake switch, (at the brake pedal), is on a separate brake switch contact than the third light wire.
my 3rd brake light is working
ledzeppac said:thanks for the responses guys.
I temporarly fixed the problem; by adjusting the tilt wheel higher it allows the lights to work fine....
I just have to drive with the tilt wheel one notch higher than ussual.
Thank you
Phil
ledzeppac said:my 3rd brake light is working, yet my two other lights do not. The blinkers and reverse works fine...
Any ideas?
I thought all three were on the same fuse?
