SignUp Now!hard pedal and brake light is on. the brakes work but not good, its like the booster is not working.How don't they work? Hard pedal? Slow stopping? Leaks? Is your brake light on?
Check the fuses first. Do you hear the electric brake motor run when you turn the key on?
Search here on the site. Many good post on this site on powermaster brakes. Also can check http://www.gnttype.org/techarea/brakes/brakespage.html for diagnosis charts.
Wow! A GN for a gift? How cool is that!!!!
did you figure out the brake problem?I am going to try and fix it first...it has been perfect until today. I am reading the powermaster diagnostics info by Ken Mosher. Hopefully it won't be major.
...I am under the impression that the conversion to vacuum brakes can be a major issue due to the loss of vacuum after the turbo has spooled. (delay in braking) Would anyone else like to chime in on this? Experience ect?
