BlackMetal
- Sep 29, 2005
Got my car up and running and haven't enjoyed it so far.
Brake pedal is spongy even after a few sessions of bleeding, and worse than that, I get a nasty brake pull to the right.
Old school "pump and hold" bled the brakes in the driveway, used a Mityvac at work, and after the Mityvac I let them gravity drip for a while too. Still getting like 2" of sponge in the pedal. Have also pumped down the accumulator two or three times to get the bubbles out of it.
Car stops straight with light brake application but if I make any attempt at a hard stop the car wants to go half a lane to the right. Have to correct with the steering wheel. Car drives straight the rest of the time so I don't think the alignment is in question.
Stock brakes were weak but never had these problems. Now I've upgraded to the LS1 front brakes, other than that it's still the stock powermaster and stock rear drum. These problems have appeared after installing the new front brakes.
I need to make sure the rear drums are adjusted to see if that will help the pedal travel, but the brake pull has me stumped.
Didn't get any grease or fluid on the pads that would cause a "grab".
This isn't fun. Installed a bunch of stuff the past few weeks to make the car faster, yet I've taken 5 steps backwards in terms of feeling safe on the road.
Where should I start?
