This was actually on june 1- 2 summers ago,
But i went + dug them up because i walked out this morning + there were 2 does on the front lawn, + i think they were both pregnant,1 of them looked like it was about to pop,i'm guessing twins,+ i'm figuring they will be born right here,the deer feel very safe in and around my yard because it sits up high with old stone walls that drop off to the lower areas,so it gives them an area where they can see anything approaching from below,+ have the walls as a barrier,+ with good escape routes, In the winter they will actually bed down at night until morning,on each side of that little white fence + under those pine trees,which also gives them some cover from the weather. it also overlooks a small brook below,+ deer love to bed down on ridges or high ground above water supplies.
I have a video of a doe + 2 very young fawns back their last summer,+ my idiot neighbor saw them come from the lower field up into my yard,+ i guess wanted to show them to his dog,a pitbull.well this beautiful scene turned into an adrenaline rush as the pitbull which was on a leash decides it wants a closer look,+ gets out of his collar,momma + the fawns take off running +
he catches the dog but all hell has broken loose + the doe jumps the neighbors fence + one fawn takes off across the street to escape the dog but one of the fawns is left screaming + running headfirst into the fence over + over,that the mother had jumped over, but a couple days later all 3 were together again out back but the doe was keeping an eye in the direction of the dogs house across the st.
I'll see if i can put it on you tube + then put the link on here,I never knew a fawn could scream like that,The video is kind of a rush because it goes from this quiet beautiful scene to everybody + everything,running,yelling,barking,jumping,crashing + screaming, in a matter of seconds.
