marleyskater420
still needs to learn
- Aug 14, 2004
RPS is PROUD to announce from WORK Turbo their brand new "G4" line of turbochargers!
This line of turbochargers are the quintessential performance piece to add to your car to transform your Turbo Regal from Mild to Wild!
These turbos are the brain child of the Mad Genius; Reed Partridge, the owner of WORK Turbochargers.
These turbos use forged point milled compressor wheels that utilize the latest in compressor wheel technology. These premium level turbochargers come standard with the "WORKed" options already implemented on the turbos, which for those who are curious, are:
* Full disassembly and ultra sonic cleaning of all parts
* 360 degree Severe Duty Thrust bearing upgrade
* Oil circuits, bearing clearances, seal tolerances blue-printed
* 3 stage balance confirmation
* Compressor and turbine wheel clearances blue printed
* Compressor inlet and exhaust outlet aerodynamics improved
* Gloss black bearing housing coating
* Improved ceramic coating on turbine housing
* Full technical support and WORK warranty
All of these turbos are completely custom built, made-to-order units. These turbos are meticulously gone through and assembled according to the output requirements of the customer and their setup. These turbos use the highest quality parts, pulling from WORK-designed/developed pieces, along with various Garrett elements as well.
These turbos represent the epitome of what WORK turbo has to offer to the Forced Induction community.
There are four (4) sizes these turbos will come in; 6262, 6265, 6465, 6765. Additional sizes may be added at later times
(stay tuned)
Pricing structure is as follows:
Prices are the same for any size, 6262, 6265, 6465, 6765
G4A is the "TA" or "Stock appearing" $1350
G4E is the "TE" or 3" inlet, 2" outlet compressor $1550
G4S is the "T04S" or 4" inlet, 2.5 outlet $1450
Add $575 to the above prices for ball bearing
Actuators for G4A/G4E are $89/69, G4S are $129
Water line kits for the ball bearing units are $129 retail
Ball bearing -4 AN oil feed fittings are $35 retail
Ball bearing Stock appearing oil feed line fittings are $45 retail (accepts the factory oil feed line)
To celebrate these new ball bearing turbos that WORK has to offer, we at RPS are having a special promotion for these new units.
A ball bearing "G4A" stock-appearing unit with all the water lines/fittings is $1,799 plus shipping, NOT including a wastegate actuator.
A ball bearing "G4E" 3" inlet, 2" outlet compressor cover style unit with all the water lines/fittings will be $1,999 plus shipping, NOT including a wastegate actuator.
A ball bearing "G4S" 4" inlet, 2.5" outlet compressor cover style unit with all the water lines/fittings will be $1,899 plus shipping, NOT including a wastegate actuator.
For any questions about these turbos, please call 707 362 6030 or email 1987GN@gmail.com
Thank you,
Tyler
Thank you,
Tyler
