brass adapter
jgines
CaTcH mE iF yOu CaN
My question is about the brass adapter that connects the turbo oil feed line to the block, there is the male end that goes into the block, female end that the oil feed line screws into, then a female end on top. My question is what screws into the female end on top :confused: If anyone out there can help out it would be greatly appreciated..Thanks
Thanks cool 84 for the info :D ..Would you or anybody else reading this know where I can get an oil pressure switch, and tell me what the function is of an oil pressure switch?
It will turn on the warning light on the dash if oil pressure gets too low. Also serves as a backup for the fuel pump if the fuel pump relay ever goes out. It will turn the fuel pump on once you get oil pressure or keep the engine running should the relay go out while the engine is running. I don't use mine, I have the sending unit for an aftermarket oil pressure guage in it's place. I'm pretty sure you can get it at any auto pats store.
