getdowngranny
Mr. Fix It
- Jan 8, 2006
I took the car out today for the first time in a few months. Made a few WOT passes and everything worked fine. Then after a while of cruising I went WOT again and it started sputtering. Car drives fine other than WOT. Every thing looks good other than AF readings. They look fine all the way up to the 140 range. The AF tops out between 140-170 max. I have a stock MAF. I suspect it to be the culprit but I don't want to throw parts at it. What else should I look at. All other scanmaster readings are normal. Also car runs and idles fine as before. Just sputtering at WOT. No powerlogger.
Can a bad coil or module cause these symptoms with these AF readings?
