I have a 2004R for sale. Has all the good stuff can ship same day and 1 year warranty.
BRF no core charge
Billet forward drum
3 clutch OD
New delco balanced Direct drum
Alto superband
Billet Servo
Parallel decked pump halves
10 vane delco rotor assembly
Billet pump rings
Harden stator Support
Dual feed 3rd
Roller low center
All new bushings
All new bearings
8 clutch 3rd
Hi psi regulator valve and spring
.521 boost valve
.400 rev boost valve
Billet anchor pin
Lock-up or Non lockup
New Psi switches if Lock-up
Harden OD ring gear
Treated input (not billet)
Pinned governor
Calibrated for positive shifts
1 Year warranty
$1850 shipped
BRF no core charge
Billet forward drum
3 clutch OD
Alto superband
Billet Servo
Billet pump rings
Dual feed 3rd
Roller low center
All new bushings
All new bearings
8 clutch 3rd
.521 boost valve
Billet anchor pin
Harden OD ring gear
Pinned governor
1 Year warranty
$1850 shipped
