SignUp Now!GNBUICK87 said:BRF Valve body
what is bo6
Valve body is clearly paint marked B06 and two pressures switches BTW 87 BRF unit .
INEEDAGN said:Pull out the governor and compare the weights to the pictured governor on Gnttype.org. also count the teeth on the governor gear. Tell us what number is on the servo cover on the passenger side outside of the trans. Look on the aluminum plugs on the end of the VB and tell us the numbers stamped into them.
GNBUICK87 said:how do i take out the servo where is it will get numbers from servo![]()
Firechicken said:Your servo is one size smaller than a 86-87 GN servo which ended in the numbers 694, but is consistant in size with an 84-85 GN. The valvebody also appears to be from an 84-85 GN as it looks like it is marked BQ. The governor is one from a GN. It has the proper size wieights and has the correct gear.
Question is the governor supposed to have 1 or 2 springs
