BRF valve body
incharge
Ok I have a BRF valve body in my car right now and want to go with a valve body that will make the car shift higher which one do I need ? also I am having issues with 2nd gear starts so I fiquire I would fix both problems at once .
I have 2 valve body types that will shift higher than the BRF but act normal driving around town,ie no late part throttle shifts.Give me a call and I can set you up as well as give you info to correct 2nd gear starts.
try this first
Loosen the TV cable 2-3 click and DO NOT go WOT. See if this stops the second gear starts. Best of luck.
Save yourself some time and trouble and contact Chris. He really does know how to make the 2004R work right.
