BRF vs. CZF ?
SSPARKY
V8 Knuckle dragger
I have a Monte SS w/a CZF transmission.
Is the BRF much different? I've been told that the BRF has a higher stall convertor and a different valve body.
I have a chance to get a BRF trans and I would be putting it behind a 355 SBC.
CZ is just as good especially for what you are doing with it. But if you have access to a brf buy it too just to have....:)
The only differance your gonna see is the servo size BR's have a slightly larger one, but either way you should upgrade to the largest billet one which is 36% larger than the stock BR. The only differance your gonna feel is the shift points, BR's are slightly higher and the CZ slightly sooner down shift points. The T/C's should both be D5's stock the BR is only rated higher due to the GN's having more torque thus the higher stall, stall is relitive to torque. Check this thread out for more. http://www.turbobuick.com/forums/showthread.php?s=&threadid=35194&highlight=cz
