In an article;
"If you want to enhance your vehicle's performance but don't want to fail the smog test, read the fine print on some of the products out there. You're going to want to find a product which has an Executive Order number. EO numbers are given only to performance products which the State of California has inspected and approved for street use. Performance Products with EO numbers can pass the smog test. Most manufactures of these products will stamp the EO number on their product. In some cases EO Numbered decals are provided with the component and required to be placed under the vehicle's hood. At any rate, the smog station which will be inspecting your vehicle must have the EO number readily available, either via a decal, stamp or the specific component's manual. Your vehicle will fail the smog test if you are not able to provide EO numbers for you performance products."
Does anyone know if the BS3 system has an "EO" number?
Signed, A Little Worried
TIA
TIA
