Precision 8285 DBB turbo for sale
ttypewhite
HP Rating: 1,325
We know you want to be the best both on the track and off. Whether you're a diehard racer or just looking to boost your daily driver's performance, Precision Turbo and Engine has what you need. For exceptional power and unbeatable technology at an affordable price, PTE can help you find the perfect turbocharger for your unique setup.
Ball Bearing Only
Turbo Features:
Exclusive CEA® (Competition Engineered Aerodynamics) compressor wheel machined from a 2618-aluminum forging
Higher efficiency and faster transient response for maximum power and performance
82mm inducer compressor wheel
"GT42 style" compressor cover with V-band discharge
85mm turbine wheel
Air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA)
Part Number: 700-8285 B
This turbo behind a 4.1 Staged motor is a absolute blast on the street. Spools quickly, and makes a ton of power and torque. This is not like a Precision 7675, I upgraded from that turbo to this one (GT42 style) and the differences are noticeable. This turbo has a 1.28A/R twin scroll exh housing.
Buy with confidence, this turbo is amazing and supports good hp with zero issues. Retails for 3,750, I am selling this for $2000 shipped to your front door.
Hmmmmmmm...
Tell me mike, what's the fastest you went with this turbo.
What converter were you running in the 7576 combo and did you change the stall when you went to this 8285?
I never tracked it with this turbo. But i can say the rpm difference in spooling was minimal, but the hp increase was substantial. Mid to low 8's would be easily achieved. Still have the same converter (19 blade I believe) I got from Dusty years back.
Okay cool. I am also running a 19 blade from Dusty. Spragless.
Dimensionally, is this the exact same frame as the 7576? Does the downpipe fit exactly the same?
If you are talking about the GT42 series turbos like this, then yes that is correct. Thats why i have stayed to this series of Precision turbos. My 76 turbo was just a simple swap, no downpipe modifications were needed. In actual fact you can leave your existing exhaust housing on your header and slide the other GT42 series turbo into it.
