Ok, here`s what happened...
We started driving in dyno in first gear - everything looked ok, but no closed loop... then we started to make pulls with bigger gear, but what happened was that spark wasn`t ok. One of spark wires was broken... damn...
Well we found out what was wrong and spark plugs and wires were changed. now it sounds fine and we also had closed loop on, but very slowly. It goes to closed loop, but it takes about 2-3 minutes before it happens and never on idle?
th 200 4r tranny changes a bit too late at wot, so i have to lift gas pedal for changing. :frown:
well next dyno time is next wednesday, so i hope to solve tranny problem before that.
I`m sorry, but language skills aren`t good enough to explain my combo. I`ll try anyway :smile:
almost stock, rebuilt engine with all new parts, arp bolts, and valve springs,stock pistons. A little improved oil channels(?)and new camshaft 109
bigger stock mount cooler, 42,5 pound injectors, ta-49 turbo
3 inch downpipe( bought it from Red and Jane armstrong couple years ago) and well flowing mufflers. I hope this helps at all?
guestion 1. - how can i get that closed loop to start right away? hot delay is 5 seconds, but i get it in closed loop after few minutes of driving and never on idle??? all of those things you pointed before are ok.
guestion 2. does old o2 have to be connected with bs3? ofcourse i have wideband o2 connected
is there some usual parameters that should work well in afterstart decay? I don`t really understand what this decay means. (i have to admit that i`m a little embarrassed because of this.)
Thanks a lot Ted A and high psi and z31,
