anyone running a BstC boost controller with a ME-R Maffless wb chip ? any issues ? I contacted Steve Y and he replied with this :
"You can use a boost controller but I wouldn't tie it into the ecm because the wgt wires might make the boost do something stupid.
I know 1 wire to the wgt solenoid is 12v all the time, that wire should be ok to use, and the other is my concern, it toggles between an "open" and ground if I remember right, to pulse the solenoid.
If you tie into that wire, I am wondering if the boost controller will override or ignore the signal coming from the ecm, I dont know."
