- Aug 11, 2001
86/87 Buick Grand National, Turbo Regal, T Type & Turbo T Performance Parts: Turbo, Intercooler, Injectors, Standalone, Engine, Intake, plus more….
With 30+ years in the game and 3 cars I am finally cleaning out the garage so I can concentrate on one car to try and make BG this year after a 32 year absence. If part is not pictured I can post or send you the most recent pictures with the date.
Everything must go, it doesn’t mean i’m giving it away. I’m flexible and open to offers, but let’s be realistic (lowballers will be ignored and or BLOCKED!). PLEASE do NOT waste MY time, serious buyers only, PLEASE!!! Don’t hesitate to ask any questions you might have. Preferred Cash local pickup, especially for the bigger items. Local pickup is Oceanside (Long Island), NY 11572
I have so many parts that I had to split them into 2 posts (one Engine & SUSPENSION and the other is all Electrical Components). Keep an eye on this post as I keep it upto date and add more parts as I sell off some of these parts.
Wanted:
A) Chad Dickey Rear Seat Brace.
B) Clean Working Power Master.
SHIPPED= Price to the Lower 48.
(NEW)= Brand New
(BNIB)= Brand New In Box/Bag
(MOCKED)= New but previously bolted on but never used or ran
(Like New)= Slightly Used with approximately 1,500 miles
(USED)= Used
ENGINE/TURBO PARTS:
30) Stage 2 On Center 153 Virgin block with New Arp Main Cap stud kit (NEW)_$5,900
31) Champion Racing Heads Irons (upgraded B-Hive Pac 1218 for Hyd. Roller Cam) (Like New)_ $2,200…… PENDING
32) T&D 1.55 Rockers for Iron Heads (Like New)_ $650…… PENDING
SOLD……33) Champion Racing Irons with Wire Lock, these were the original run of heads before they stamped them with the Champion CNC name. (they worked great and I never blew a headgasket, these need to be freshened up) All ports are the same exact measurements as the ones that are sold today (USED)- (includes 3 correct Fel Pro gaskets) ……SOLD……
34) Champion Racing Heads Upper & Lower intake with billet fuel rail (Like New)_ $1,850 shipped
SOLD……35) Champion Racing Heads IAC relocator (Angle Boss) (Like New)……SOLD……
36) Champion Racing Heads Throttle Body Vacuum Block off plate (Like New)_$20 shipped
37) Precision Turbo PTE GEN 2 PT6266 DBB .85 A/R (Mocked)- $1,400 shipped…… PENDING
38) Comp Cams XR3 216/220 Hyd Roller Cam with Morel Lifters (Like New)- $600
39) Comp Cams 206/206 Hyd Roller & Comp Cams Roller Lifters (NEW)- $750…… PENDING
(lifters were put into a bucket of oil but never used or installed)
SOLD……40) TA Valve Cover (Like New)_……SOLD……
41) Harland Sharp Heavy-Duty Roller Rockers 1.60 (S60360K) (BNIB)_ $700 shipped
42) Billet Aluminum T-Stat (Thermostat) Housing & Clamp combo (Like New)_$45 …… PENDING
43) GN1 Throttle Body 72mm (no need for IAC relocator/angle boss) (Mocked)_$315 shipped
44) GN1 72mm Throttle Body Power 6 Plenum Only (Mocked)_$310
45) GN1 Billet CNC Throttle Body 1" Spacer Tapped for Vacuum (Mocked)_$120 shipped
46) GN1 Billet Fuel Rails For Stock Intake Manifolds (Mocked)_$320
47) GN1 KB3 SS Headers with 46mm Wastegate, Blow Off Tube, and Boost Controller Combo (Mocked)_$950…… PENDING
48) GN1 3" Down Pipe with a Flat Flange no Wastegate & with Test Pipe (Mocked)_$425…… PENDING
49) Racetronix Teflon Fuel line Kit and Filter (-8 feed & -6 SS braided black conductive coating)_ need AN fittings at pump (Like New)_$350…… PENDING
50) Racetronix Billet Fuel Psi. Regulator (BNIB)_ $140 shipped
51) Racetronix Fuel Pump Hotwire Harness (USED)_$45 shipped
52) Racetronix Fuel Injector Harness with Hotwire Upgrade (1 piece harness) (USED)_$85 shipped
53) Accufab Fuel Pressure Regulator with 2x O-Rings (Mocked)_$130 shipped…… PENDING
SOLD……54) Accufab 70MM Throttle Body (bead blasted- Not Polished/flat) (BNIB)……SOLD……
SOLD……55) Precision plenum (bead blasted- Not Polished/flat) (BNIB)……SOLD……
SOLD……56) RJC A/D Power Plate for Precision plenum (BNIB)…… SOLD……
SOLD……57) RJC Drivers Valve Cover Breather (Mocked)_…… SOLD……
58) RJC Valve Cover Extensions (BNIB)_$100 shipped…… PENDING
59) RJC A/D Power Plate for Stock Plenum (Like New)_$50 shipped
60) 3" RJC Downpipe with test pipe (O2 Bung on the bottom, bung cap/plug included) (Like New)_$550 shipped…… PENDING
61) RJC 315 FMIC with black coated pipes (has 2 holes on up pipe- for Alky and Vacuum) (Like New)_$800
62) BGC Stretched SLIC (has some cosmetic damage on the backside and air scoop, will need to be psi tested) (USED)_$400…… PENDING
63) HD Wastegate Solenoid for Stock style & TA housing (USED)- $75 shipped
SUSPENSION/EXTERIOR PARTS:
80) UMI Performance Rear Non-Adjustable Upper & Lower Control Arm Kit 302116-R (Black) (BNIB)_ $385…… PENDING
81) Detroit Speed Rear Tubular Sway Bar Kit (1 ⅛”) Diameter (Like New)_$290
SOLD……82) HR PartsNstuff 3.8 Drivers side Motor Mount (Like New)_……SOLD……
SOLD……83) HR PartsNstuff Transmission Mount (Like New)_……SOLD……
84) Wilwood D154 Front Caliper Kit (Like New)_$350…… PENDING
85) Power Antenna-Universal (BNIB)_ $40 shipped
86) F Body Radiator in great condition (Like New)_$50
87) Rear Trunk Spoiler complete with both ends and OEM quarter End caps- (USED)_$900
88) OEM quarter End caps- (USED)_$45
89) Eastern Perf 3 inch High Performance Catalytic Converter- (New but has surface rust)_$350
90) Dennis Kirban Rear Seat X-Brace kit- (USED)_$60 shipped …… PENDING
91) Front Grooved Rotors with new bearings (Standard Lugs, NOT METRIC) (Mocked)_$150
Wanted:
(NEW)= Brand New
(USED)= Used
ENGINE/TURBO PARTS:
