Sep 20, 2007 #1 V vin1489 New Member Joined Aug 24, 2007 Messages 32 What is the factory color for the upper throttle body? And does someone make it in a rattle can?
Sep 20, 2007 #2 T TurboDave RIP DAVE Staff member TurboBuick.Com Supporter! Joined May 24, 2001 Messages 14,013 vin1489 said: What is the factory color for the upper throttle body? And does someone make it in a rattle can? Click to expand... No color, uncoated aluminum.
Sep 20, 2007 #3 V vin1489 New Member Joined Aug 24, 2007 Messages 32 If I media blasted it would I need to clear it??
Sep 20, 2007 #4 G godwingn87 New Member Joined Jul 19, 2006 Messages 39 I blasted my intake and plenum a year ago and never clear coated it.. It still looks good..
Sep 21, 2007 #6 T TurboDave RIP DAVE Staff member TurboBuick.Com Supporter! Joined May 24, 2001 Messages 14,013 vin1489 said: If I media blasted it would I need to clear it?? Click to expand... Clear coat would probably discolor with age and heat soak.
Sep 21, 2007 #7 D dan lephart Member Joined Nov 10, 2002 Messages 447 coate Eastwood makes a clear hi temp that they say will not discolor... Used it on my valve covers three years ago and they still look new! No more cleaning to keep them looking good.
Sep 21, 2007 #8 J johnnyttype Active Member Joined Apr 18, 2007 Messages 1,313 i used an SOS pad and it came out lookin real nice, along with turbo shield and valve covers!
Sep 21, 2007 #9 U UNGN Can't Re- Member Joined May 24, 2001 Messages 14,029 I welded a plenum in one and had to paint it to hide the heat discoloration. Any high temp aluminum spray should work fine. The color you need is "aluminum" or "cast Aluminum"
