I have a 109 built by hye tech came off my 86 gn engine has about 500 miles since the built.
Block tanked mogged bored .030 honed surfaced 2 steel billet center main caps ARP main bolts and aligned bored and honed new cam bearings and freeze plugs
Crank 4340 steel crank with oiling holes chanferred
Rods 4340 scat beam with ARP rod bolts and for floating pistons
Pistons JE forged .030 Rings, JE file fit plasma moly
Bearings clevite 77h series STD
Cam and lifter Comp custom hyd roller
T-chain edelbrock true roller balanced rotating assembly oil pump melling high volume
Heads strut ported and polished new guides cut and installed p.c. seals new stainless valves 1.80 and 1.50, 3 angle valve job and isky springs, retainer and keepers to accomodate cam specs
Manifold ported to match heads
Rockers T&D 1.60
Push rods Isky chrome moly
Head bolts arp, valve covers champion aluminum
Plenum Hye-Tech design
Injectors F.A.S.T. 65 lbs
RJC pulleys
Throwing in headers and downpipe, intercooler stock aluminum ii am sure i forgot some other stuff
$5,500 Also have the roller $7,000 for EVERYTHING!!!
Rockers T&D 1.60
RJC pulleys
