- Aug 11, 2001
The engine has JE pistons, H-Beam Rods, stock crank, stock caps with ARP studs, Comp Cams Hydraulic Roller Cam (212-206, I have Cam card), Comp Cam pushrods, Weber Hydraulic Roller lifters, stock heads with bowl work and some port work clamped down with ARP studs, stock upper intake with EGR removed. Comes as seen in the pics (balancer, crank pulley, crank sensor and bracket, cam sensor with New Caspers cap, oil dipstick tube). Has an 84-85 passenger side valve cover on it. I would say the motor is capable of handling 4-600 hp safely. Don’t hesitate to ask questions.
The motor was built by an engine builder out of the Chicago area that has since passed away. A long time and well known standup guy in the Buick community vouched for the motor. As a matter of fact, he has a similar build/engine in one of his personal cars built by the same engine builder. Serious inquiries only please, PLEASE don’t waste MY time. If you need permission to buy, don't contact me. I would be willing to travel and meet a distance within reason. Prefer local pickup. I’m located in Oceanside (Long Island), NY 11572
