i cracked one of my fiberglass replacement fillers a while back. At the junk yard i found 2 perfect origional fillers that were still flexable, for $2 a piece
so i get them home and tryed using a chemical paint stripper on one, the side i don't need just to make sure it will work and it ended up bending, i dont' know if its just from me holding it and it fel over and hasnt' straightend out yet, or of the chemical did anything to it.
so on the other piece i used a scotch bright pas on a die grinder and tryed to take off the paint. it got the paint off, and some of the plastic.
so now i have one warped one, and one filled with little roun gouges. i can probably bend the one straight, and once its on the car i dont' think it will be a problem.
the other one is going to be a mess. body filler would easly fix the gouges, but since its rigid will that give me a problem? is there something that works?
its a little late now but what works good for stripig the paint on them?
