Bumper fillers testamonials needed.
87gn-newbee
Need to get some new ones and have read quite a few post about ABS and fiberglass fillers. I want to hear what you bought.
1. how was the fit
2. did they come pre drilled
3. how much were they and where did you get them.
4. how much prep work
Was told that the Danco(?) were good but not predrilled. Do you think having them predrilled is better? or not so you can do the lining up your self.
What about S$K rears and GM front? Also read probablly the best bet going.
Dan
My S&K rears fit okay. I sent the S&K fronts back twice because the dimensions were off. I finally got my money back and just bought new GM fronts. Since you can't get the fronts now you have to keep your eyes peeled. I wouldn't run the Dancos either.
I prefer the ones you drill yourself. Everyones car is slightly different. Body bushings wore or bumper aligned differently etc...
This way you put them exactly where you want them.
Buy Danco
I bought a set of Dancos, not predrilled but its better that way.
1) Get the fillers painted first, then drill out the marked holes.
2) Trial fit and either enlarge or slot the holes for exact fit.
3) A 5/16 drill bit will do the trick, should take an hour to do all 4.
4) Hang the bumpers
I'm very satisified with the quality and customer service from Danco. Got them off ebay, $185.00 shipped.
James
