1984 t-type
Murphy's Law
- Jul 11, 2010
When i jack my GN up the bumpers contact the fillers and over time have caused chip marks, what is the cause of this bad body bushings ?
SignUp Now!Where are you placing the jack when you pick the car up?
You never pick these cars up by the frame extensions. Always pick them up just behind the front wheel or just in front of the rear wheel where the frame is boxed. Never pick them up along the open "U" frame channel between the front and rear. You will bend it. I see this all the time.Either front or rear frame rails. Sometimes rear axel or front control arms.
Yes. It's likely the body bushings are rotted or missing. Check both top and bottom. And install the ones that the factory left out.When i jack my GN up the bumpers contact the fillers and over time have caused chip marks, what is the cause of this bad body bushings ?
Body bushings for sure. Here's a thread that shows just how little our cars flex with just polyurethane body bushings and no other bracing and this is on a T Top car!
Just worried about the cage nuts spinning, if it weren’t for that would be a piece of cake job.
Whoops, I'll try again.Body bushings for sure. Here's a thread that shows just how little our cars flex with just polyurethane body bushings and no other bracing and this is on a T Top car!
