m233roller
Banned
- Jan 25, 2002
Here's a bunch of small parts and almost all of these are off my 40,000 mile show car.
I - Powermaster off my 40,000 mile GN. Looks darn near new and works perfect. Don't like the blue reservoir I can remove all the blue.
$550
2 - Under steering wheel gray collar, like new. $25
3 - Two perfect a/c vents. $30
4 - Stock passenger side breather complete. $25
5 - BLO esc module. $50
6 - NOS fan delay relay Part # 25527402. $50
7 - New a/c Delco dual window switch with bezel. $35
8 - New after market left door handle. $15
9 -Stock used but good wastegate solenoid. $45
10 - New bezel & nut (black) for power antenna. $25
11- Slightly used 87 IAC motor. $25
12 - Original pair of radio knobs. $10
13- Two perfect trunk adjusting rubbers. $10
14- Stock vacuum L for FPR. $10
15 - Original cam sensor hold down bolt and washer. $5
16- Original plastic cable holder on the frame. $5
17- Gray astro roof plug. $5
18- Heater rheostat $10
19 - New shift indicator plate. $10
20 - Used 87 power steering cap. $5
21- Original fuel rail cap. $5
22 - Perfect T-Type center horn cap medallion. $35
23- Used but good bare burgundy shift handle. $25
24 - New water nipple for manifold. $5
25 - Original plastic connector and guard for oil pressure switch. $5
26 - Left and right seat belt retractors, ones in the door jamb. Some wear on flipper lever but very usable. $50 a set.
27 -Black license plate mount between T/L's. Perfect put it on and go. $50
28- - Perfect set of hard vacuum lines. $75
29 - Stock and perfect floor shifter out of my show car. $125
30 - ECM out of my 87 GN show car. Worked perfect. $125
31 - Very nice console shifter plate out of my show car. $125
32 - Brand new Walbro 255 fuel pump kit. $100
33 - Powder coated blue throttle body cable bracket. $45
34 - Front license plate mount. Good shape. $25
35- Passenger side relay mounting bracket. Redone. $25
36 - Nice chrome cover for stock maf sensor. $30
37 - Refurbished cruise control mounting bracket. ( Black ) $20
38 - Brand new Caspers knock sensor. $50
39 - Complete Innovate wideband MTX - L Digital A/F ratio gauge with one good & working sensor & one brand new sensor. They are Bosch 17014 sensors. $150
No pics. yet but I have upper & lower rear control arms from my 40,000 mile car. Both are in perfect shape.
Uppers are UMI non adjustable black arms. $75
Lowers are Metco billet aluminum arms. $200
Rear hood molding, excellent shape. $50
Trunk lid lower edge molding excellent shape. $50
Perfect cowl to hood rubber seal. 25
Perfect stock driveshaft. Stripped & painted with HI Temp gray steel paint. Out of my show car at 32,000 miles. $75
Perfect set of black wiper arms. $100
Pair of Ebach 1in. rear lowering springs. They are silver in color & Like new. $50
Will have a complete 87-GN analog dash wiring harness. NOT all chopped up, yes a couple of places were I spliced in for gauges. $150
Will have a complete 87-GN engine wiring harness. A couple of sensor ends cut off and the plastic L shield is broken. I have a couple of those L's I'd throw in. $250
87 GN grille. Had a small chip on one of the fins so I made the one on the other end just like it. Very unnoticeable. $250
ATR rear sway bar that's been sandblasted and painted with Hi Temp gloss black paint. $150
I have a complete set of black body side moldings that are very close to our original ones. They do have a few bruises on them from door's hitting them , not bad though. $50 for the set.
I have the complete P/S set up off this car. Pump is only a year old and has a billet pulley on it. Reservoir is like new as are the hoses.
$250 for the whole set up.
Steering column out of this car, it is complete with tilt lever and turn and cruise lever. Factory original levers, chrome and white writing is excellent. Does have some paint wore off on the very top of it. With key. $200
Rebuilt steering gear with less than 3,000 miles on it, with pitman arm. $100
Pair ( left & right ) NOS in the GM boxes black H/L bezels. $300 for the pair.
PLEASE NOTE ALL PARTS ARE PLUS SHOPPING & PAYPAL FEES.
Thanks Mike
$550
Thanks Mike
