Bunch of stock parts...
d0n_3d
Boost is good.
Set of 6 used 30 lb injectors with matching turbotweak chip - $100 shipped
Brand new Walbro 20000169 255 HP fuel pump with correct TR kit - $80 shipped
Brand new Spectra TR fuel tank sending unit. $100 shipped
Stock turbo shield uncut - $50 shipped
Used billet adjustable fuel pressure regulator - $50 shipped
Used stock 86/87 fuel rail - $50 shipped
Used stock 86-87 coilpack and ignition module guaranteed good (original GM units), includes good set of plug wires - $100 shipped
Stock used fuel injector harness - $40 shipped
Stock used 86/87 belt tensioner in good shape - $50 shipped
Used set of custom Buick valve covers, have a black powdercoat finish, $125 shipped
Stock used unported 86/87 complete intake with throttle body and plenum, includes billet vaccum block, $250 shipped
Used stock black powdercoated turbo shield question mark bracket - $50 shipped
Used stock 86/87 accessory bracket - $50 shipped
Stock used 86/87 turbo complete with elbow and adjustable wastegate actuator, has minor side to side shaft play, probably still good to run - $125 shipped
All pics can be found here:
http://www.facebook.com/album.php?aid=47769&id=1647758035&l=9abde504ce
Paypal accepted blackout87gn@hotmail.com
interested in the billet adjustable fuel pressure regulator pending pics is it a kirban?
Here we go again Don, i'll take the tensioner pulley you have there as long as it has had no repairs to the ear (hole) where they usually bust. I'll paypal to ur blackout addy?
sale pending on tensioner, inj harness, acc bracket, and fuel rail, also sale pending on fuel pump and ignition module assembly.
i'll get a better pic of the sending unit tonight after work
valve covers should fit 85 i don't think they changed the heads that much over the years...
Payment received on fuel pump and ignition module assembly.
I uploaded more pics of the sending unit.
Don, did someone beat me to the tensioner or is that me your awaiting pymt? I'll get you in the morning if i had first dibs. thanks
Thats fine Don. Just wanted to make sure it wasnt me you we're waiting for a payment from. If it falls thru look me up. thanks
The following parts have been SOLD:
Fuel injector harness
Accessory bracket
Valve covers
Tensioner
Coil Ignition combo
Fuel Rail
Fuel Pump
Everything else is still up for grabs!!!
