Foreword: I know absolutely nothing about chip burning or programming, but would like to start.
My primary need is a burner so I can make smog chips for some of the local folks. From what I gather, I will need a programmer and a UV eraser (DataRase II EPROM eraser?). I have read of several folks on here having difficulties burning 2732A eproms with certain programmers. So then what? In another thread, 2QUIK6 mentioned using AT29C256. Is this a direct replacement to the 2732A that doesn't need a UV eraser?
Later, as time permits, I may start fiddling with programming, though not to make the perfect chip... just to learn a little something about the simpler aspects of programming.
I've looked up Pocket Programmer, but it doesn't list 2732A (though it does list 2732... different?). jdr.com has an EP1. Many others, more expensive.
TIA!
TIA!
