Buying Advice - What to Look For ?
LIGHTEMUP
I am looking to buy my first GN, always wanted one...it is now "go time".
Before I make any bad deals can anyone offer advice on what to look for that says "stay away". I know they had bad paint from the factory so if it has been repainted, make sure it was stripped to bare metal and they removed the side windows (I was told a good body shop would remove the windows to repaint, a cheap job would not).
I know lots have been modded, is that good or bad? should I be looking for a completely unmolested car? which mods are good or bad?
Thanks !!
Only thing that would worry me about the body; is there damage under that shiny paint job?
Mechanically, if the car's been modded- can the owner document the mods, or are they here-say from a past owner?
How hard has the car been run? Good to know that, too...
look for RUST.....in door jams by the hinges,trunk,etc. if you want a t-top car,its best to look close (even pull some trim off) and check really close.
mods are OK IF you see some kind of monitor for knock.IE; scanmaster,knock gage,etc.
take a Friend who wont let you buy on emotions.
keep searching here for more info......youre at the right place;)
I am looking at one this weekend, person selling it for deceased family member so not a lot of info. He told me engine was rtebuilt a few years a go but did not know under what circumstances. He recalls the catalytics were punched through and a stage III chip added? does that make sense? car only has 36K miles and is original owner (person who died, bought it new). History looks good but should I be worried the engine had to be rebuilt so soon?
Thanks for the info so far !! I was going to bring my Brother along (licensed body man) he will be able to tell what's what with the paint job but turbos-intercoolers etc is all new to both of us. No T- Tops, I was warned from a T-Type buddy of mine that T-Tops rattle, leak and weaken the frame strength.
I can't wait to get out there and start spanking some V8's...already got my plates..EATS V8S. I have always wanted a GN so the car I buy, I want to keep for awhile. Thanks in advance for any advice.
This is a guide to assist you in purchasing a Buick Turbo Regal. The information presented here is based on a mostly stock car, as it would be impossible to anticipate all the modifications that could be present. We have tried to focus on topics which are of specific concern to the Turbo Regal, so don't rule out standard checks you would do with any car. Finally, the amount of tire-kicking the owner will allow may limit the usefulness of this list. Use your street sense as to whether they are being cautious, or just trying to hide something.
THE TECH CHECK
When you first approach the car, you want it to be completely cold. Try to get to it first thing in the morning.
Pre-Drive Inspection
BODY- Stock paint is a lacquer type and the '87 cars had a thin clear coat over the color which could fog using certain waxes. Any paint that looks "too good" for it's age is suspect, since these cars had characteristically poor paint jobs from the factory. There was, in fact, an unofficial recall on late 80's GM paint jobs. On 2dr coupes, look for cracks or waves by the top of the pillars which separate the front doors from the rear windows. These are caused by the body flexing from Buick torque! Rust is prevalent on the bottom of the passenger doors, in the bumpers, and under the rubber of the gas tank straps.
ECM - If you have access to a scan tool such as TurboLink (tm) , check for stored error codes. EPROM changes are very common in these cars, so ask the owner if the original is available. You will check for stored error codes again after your test drive. Jumper across the diagnostic pins and the following should activate- low speed fan, SES light, IAC motor, wastegate solenoid. The ECM itself is located behind the kick panel on the passenger side foot well. Abnormal wear, fit, or missing clips in this area can reveal frequent EPROM changes.
IGNITION - Examine the spark plug wires, since they tend to break down quickly from heat. Aftermarket wires aren't always better. The coil pack and ignition module are also subject to thermal decay, and most people prefer genuine AC Delco replacements for these and most electrical components.
TURBO - The stock turbo is a Garrett AiResearch unit. Access the turbocharger inlet (compressor) side by removing the air intake (MAF) hose. Spin the compressor wheel shaft- it should move VERY easily. Examine it for any visible "play" and check the fins to see if they are damaged, shaved at the ends, or can touch the bell housing. Either is bad news.
Remove the intercooler hose from the turbo outlet (intake tube on non-intercooled models), and check for wet or caked oil in the outlet tube area and the intercooler. Buick placed a metal tube from the passenger valve cover to the turbo inlet, however many people cap the inlet and put a breather on the valve cover. If this "bypass" modification has been done, there should be no oil in the turbo outlet tube (unless it's leaking from the turbo bearings!). If not, it is likely this area will be wet, because oil is inadvertently drawn in through the metal tube.
If you can, measure the wastegate actuator rod length. You must remove the rod end from the wastegate lever by releasing the c-clip. Be careful, since the clip tends to spring off suddenly. The stock rod is fixed in length at 5 1/4". Any shorter indicates the turbo is likely set for higher boost than stock.
Due to the excessive heat of the turbocharger, synthetic oil and/or frequent changes (<3000 miles) are recommended for these cars. Ask for documentation of this and all other service!
INTERCOOLER - The 84/85 series TR's were _not_ factory-equipped with intercoolers, but the 86/87's were. The stock location is between the radiator and the crank pulley. The stock connecting hoses were thin black hoses with stainless bands to hold them on. Most aftermarket replacements are blue or black, much thicker, and may have a stainless weave on the retainer rings. Look for a tag on top of the intercooler marked "Garrett" with a serial number. Common aftermarket upgrades include extending the stock intercooler or replacing it with a larger unit behind the front grille. Any aftermarket or home brew intercooler should be examined for workmanship.
EXHAUST - Stock design is 2 1/4" with one "crossflow" (one-piece with 2 pipes in/out) muffler and slant-cut tailpipe ends exiting the sides. The stock tailpipes never exited the back under the rear bumper. Check the driver's side header for cracks, especially between cylinders 5 and 3.
TRANS - The stock transmission is the 4-speed Turbo Hydramatic 2004R. Check the TV valve adjustment at the engine throttle body- the throttle plate should be able to travel a full 90 degrees. If not, the shifts may be artificially firmed up by over tightening the TV adjustment. A healthy transmission with stock shift points allowed a firm (but not harsh) shift pattern. Any "slack" feel between shifts could indicate a problem. Remember this on your test drive.
REAR END - Check the travel of rear axle by examining the pinion snubber, a short rubber stopper above the differential. The stock snubber is about 1 inch long and should show very little evidence of contact. Aftermarket snubbers, however, can be a few inches long and are expected to contact the differential housing. Since the rear end gets the brunt of the torque, check carefully for cracks and broken welds. While you're down here, also look for little rubbery fragments embedded under the bumper and wheel wells. They come from the local race track.
All TR's came with 3.42:1 gearing stock. Positraction was available but not standard. For more info on codes, check the rear end code page. In spite of the RPO Codes, beware of foul play here- it's possible for people to swap the GN rear end components for lessers. The 8 1/2" limited-slip differential is the most desirable
OIL - check oil level. When you wipe the dipstick, there _shouldn't_ be a metallic tint to the oil on the rag!! Stock oil filter is the AC Delco PF-47, however the taller PF-52 is acceptable and has greater area of filtration. Any other filter may lack the anti-drain back feature of these two AC Delco models.
FLUID LEAKS - Check under the car for leaks of any kind. Most TR's leak some oil from the rear main seal area, which will show up as wetness on the flywheel cover. Leaks are also common around the oil filler tube on the driver's side valve cover. This leak can run down the back of the engine and mimic a rear main leak. Note all existing leaks and dry them off well with a rag. After the test drive, you will re-examine them to get an idea of how bad they are leaking.
BRAKES - the 86/87 TR's use the much-maligned Powermaster brake setup. Check for a gray switch on top of the master cylinder to make sure the brake recall was performed. The stock (and very dangerous) pressure switch was all black. The large round ball on the system is the accumulator. If there is a yellow warning tag on it, it was likely replaced at some time- this is common. See the technical article at for more information on Powermaster testing.
TIRES - Stock size for the Turbo Regal's are 215/65/15 on 15 X 7 rims. Larger or smaller may affect gearing, rub on turns etc... Remember this on your drive test.
Back to Table of Contents
Just Before Start Up...
In ignition, but not started, check all the idiot lights. The brake light should go off within a few seconds.
Start 'er up....should be an easy start with no throttle assistance. Some mild black smoke from the tailpipe is acceptable, as long as it clears quickly. Too much, the car is running rich. Blue smoke indicates oil burning and excessive white indicates water; either could be a head gasket problem. Listen for unusual noises- lifters, rod knock, shaft play....light injector tick is OK, see below. If you can connect a vacuum gauge, do so. This can tip you off to a leaky head gasket, bad valves, etc.. In Park, a reading between 12" to 15"Hg with an inch of "float" is normal.
OIL PRESSURE- Start up pressure is generally above 60psi, idle in the high teens, and highway pressure is generally in the high 40s. Buick spec is 37psi at 2400rpm.
TEMPERATURE - Stock thermostat is 190 degrees, but common replacements are 180 an 160. Once it's warmed up, take it out for a spin.
Drive Test
With the brake firmly applied in Drive, apply the gas and see if the turbo builds a few pounds of boost. A turbo "whistle" is normal, but there shouldn't be rattling, knocking or hesitation.
SEAT OF THE PANTS/HAUL *SS TEST!...anyone with a pulse should get this one.....
RPMS/GEARING - On a flat open highway, maintain a speed of 60 mph. You should be in overdrive and this should equate to about 2100 rpms. If not, you may have non-stock gearing, or TCC problems.
TCC (Torque Converter Clutch) - While maintaining 60 mph, gently tap the brake pedal for a half second with your left foot while maintaining throttle with your right. The rpms should jump up as the TCC releases and then return to ~2000 as it engages again. If this test fails, it may indicate the car was driven with an unlocked TCC, which could cause very early transmission failure. A weak 2-3 shift is a common sign of wear.
SHAKES, RATTLES, & ROLLS - Try a few bumpy roads at different speeds to expose noises. It's common for the windows to rattle when down, and leak when closed on the highway. T-TOPS are prone to leaking, squeaking, etc... so listen carefully for noises from them. T-tops are generally less desirable for strip cars, as they tend to decrease stability.
BEFORE YOU SHUT OFF THE ENGINE, verify the function of all accessories. Put the A/C on for a few minutes. Leave the A/C on when you kill the engine, and make sure the coolant fan stays on for 7-10 seconds. This is a function of the fan delay relay.
Post Drive Checks
FUEL SYSTEM - Stock fuel injectors are solid black. It is normal for them to make a slight ticking noise. Do not confuse this with noisy lifters or valves. If possible, put a fuel pressure gauge on the car and turn the engine on. The stock fuel regulator is the Bosch 280-160-233, which has no adjustment. Fuel pressure in the mid to high 30's is normal for idle. Turn off the engine and make sure the line holds pressure for at least several minutes. Fast loss of pressure could indicate any number of faulty fuel system parts.
ECM - Follow up on the ECM again for trouble codes.
FLUID LEAKS - As a follow-up, check the underside again for leaks, which should all be fresh if you wiped them before. Check oil level again
COMPRESSION - If you can do a compression test, look for around 150psi per cylinder with no more than 10% variance.
SOME OTHER TR CONSIDERATIONS
VIN STAMPS - The windshield VIN should match the engine VIN, the transmission VIN, and the VIN listed on the option code sticker on the trunk lid. A Buick dealer can enter the VIN into the computer and check any warrantee/recall work. The VIN reveals some information about the car.
INSTRUMENT PANEL - The digital IP was an option, but has shown to be less than popular, since it only has a 'turbo lamp'. The analog IP had a 15psi LED bar gauge. Both were limited to 85mph readout. A GNX-style dash is a popular aftermarket accessory in TR's, since it has expanded analog gauges for speed, oil, temp, fuel, and boost.
INTERIOR - The standard 84-87 GN interior was black and gray. Some rare GN's received the Lear Siegler leather seats, in a light and dark brown combo. T-types could have any color interior. The door pull-straps, the plastic steering column center, and the shifter handle are known weak spots. Check the condition of the pedals, carpets, and other controls to confirm the wear supports the odometer mileage. The gear shifter plastic has a grain which often wears smooth under normal use.
RPO STICKER CODES - are located on a sticker on the trunk lid. They define what options the car had from the factory.
RECORDS - Some of these cars have changed hands many times. Maintenance records (or lack thereof) can show this. They are also favorites for modifications. Make sure the workmanship is to your satisfaction!
AUTHENTICITY - It is common for people to clone regular Turbo Regals to resemble Grand Nationals. Mechanically, they could be purchased identical, but there were different fascia and graphics. The RPO code for the factory Grand National package is "WE2". In short, here are a few characteristics to look for on 84-87 GN's: factory GN's have unique GN emblems, 2 on the front fenders, 1 on the driver's side trunk lid, and a smaller one on the passenger dash trim plate. The 86/87 series has "intercooled" emblems under these 2 fender emblems. The word "Buick" only appears on the dash trim plate and the front grille.
The GN has a unique interior design, consisting of gray on black with the red/yellow "6" emblems on the headrests. The 84-87 GN s were all black, had no hood ornament, and no exterior chrome, with the exception of the wheels and the front grille (the '87 grille was all black) The Grand Nationals also had a unique 3-piece rear spoiler. Remember, all these characteristics could be forged or transplanted.
THE 1987 BUICK GNX
The GNX was a "collector's edition" Grand National with several aesthetic and performance modifications. There were 547 GNX's made. What follows is a summary of these differences:
245/50/16 front & 255/50/16 rear tires mounted on 16x8 black "honeycomb" wheels
fender flares on each wheel well
functional air louvers on the front cowls
analog instrument cluster with Stewart-Warner gauges
auxiliary transmission cooler mounted behind the front grille
"improved" Garrett turbo with ceramic impellers and a custom GNX cover
"improved" intercooler with serial number
GNX emblems
serialized plaque on dashboard
ladder torque bar and panhard rod for better traction
GNX graphic differential cover
"improved" hydraulics in the transmission for firmer shifts
dual exhaust from cat-back with separate mufflers for each pipe
It is STRONGLY suggested that you contact an expert, such as Rob Wilson before considering a GNX purchase. The appearance of these cars is often "cloned" on regular Grand Nationals. Rob keeps a GNX registry. See the GNX Home Page for more information.
THE 1989 PONTIAC 20TH ANNIVERSARY TURBO TRANS AM
"The fastest Trans Am ever made" according to the Pontiac literature describing the 25th Anniversary TA, this is yet another collector's car. It is basically a standard Pontiac Trans Am outfitted with a Buick 3.8 SFI Turbo engine, identical to the Turbo Regal engine, but with a few improvements.
Again, it is STRONGLY suggested that you contact an expert, such as
There are some good cars out there but make sure you have an idea what you are willing to spend before you go. Also, all the above info is great but also make sure the car is running strong before you buy it. Have the owner drive you and make sure you watch for knock on the scanmaster (The right LED that starts out as 0.0 and should not move or maybe just a blip of 0.5 -1.0 when floored. That will show you that there is no knock because you usually can NOT hear it. No KNOCK under hard acceleration is a very good indicator that many things are right about the car. If there is an audible knock detector you will hear it beep when you move the car from park etc and that is normal, but under acceleration the best case is no beep at all. If scanmaster equipped then also monitor BL as you are driving around. (click the left button until BL shows up)BL(M) should be very close to 128 under all conditions. Within +/- 5. Any more than that and there may be a big reason why the computer is adding or pulling fuel to keep the mixture correct. My opinion is that since you want to terrorize V8s ASAP, buy one that is already modded and running great. You will be fixing things soon enough so you might as well have a few days of fun before something needs adjusting or replacing.:biggrin:
Thanks DailyDriver
My T Type buddy told me the same thing, get a car that is running right, accept no excuses.
Be sure the rearend is an 8.5 rearend. I recently bought a car that a past owner had removed the 8.5 and installed a Regal 7.5 . Also Check the code on the tranny tag and confirm its the correct for 86-87 BRF code.
How do you check if the rear end is correct? the car I',m going to look at, I asked if it was posi, he said the first car his Dad got was not posi so he returned it for a posi car. I was told to look for the G80 code on the trunk tag but underneath the car, how do you tell if it has been changed?
Whats your e mail? I'll send you pictures of both rears.
My 86 has the wrong rear in it mine has a 7.5 with easton posi the 8.5 has 2 large ears on either side as you looking at the cover bottom corners
Thanks Everyone for all the Info !
Armed with all these great tips, I can steer clear of bad deals.
Thanks Again !!
If you let us know where you are located maybe a member can help you out as well. If at all possible take someone with you that knows these cars, you will be VERY glad that you did. Your new found excitement that you are finally going to purchase a car could very well bite-you-in-the-wallet if you are not careful and buy the first car that comes up. It is a buyers market right now with the economy being what it is. With winter around the corner there will be a good crop of cars to choose from in my opinion. Don't rush into this and you will do well.
Good luck with your search
Bryan
Thanks Bryan
Does anyone know how to check if the car is numbers matching? I know the VIN on the dash and engine should match, but where is the engine number lcoated? and does it match digit for digit to the dash VIN?
Henry
look for the rpo label under the trunk lid,its has the engine code (8th dig of the vin reading from left. 7=lc2 turbo)if its an 87. also,if its a GN look for a we2 code.posi is gu80 i think......good luck...:biggrin:
