Buying my first GN!
SS_Sean
Pro Bracket
Got a deal worked out on a 1986 GN, and we're working on getting some money out to him. Here's the car:
Has a rebuilt motor with some performance goodies, cam, etc. Looks like a solid runner.
Front seat uhpolstery is worn out, and headliner is crap (as usual). Rest of the interior looks solid. Has the Astro roof. Never seen one in person, but they look pretty cool.
Engine: 13,000 miles since rebuild.
212/212 456* lift comp cam
Clevite 77 Bearings
Forged TRW Pistons
Main oiling holes enlarged to accomodate H/V front cover.
24 pounds of oil pressure at hot idle
10,000 Miles on motor
Billet Mains with Arp Main Studs
10/10 stock crank
Resized Rods with Arp bolts
High Volume front cover
Royal Purple oil since break-in
Fuel System:
Hot wired walboro 340 pump with 36lb injectors and an adjustable regulator.
All AutoMeter gauges including Oil Psi, Fuel Psi, and Boost/Vacuum.
Scanmaster
Has a translator plus
150k miles on chasis
Stock Turbo
Stock Intercooler with the Duttweiler enlarged neck
New Shocks
Fairly New Brakes
Custom short ram intake with K&N filter
Raised valve covers
I'm new to turbos, so I'm not sure about the computer stuff, like the Scanmaster and translator plus, but the motor sounds solid. They always need a bigger turbo. :biggrin:
my we4 has an astro roof, its pretty cool. i need it, as i have to have the sun cover always pulled back. otherwise my head hits the roof. im only 6 foot. good luck with it!
