Originally posted by TRiv
*Centerline of input shaft/pinion, to left and right sides of housing
I can do this tommorrow for you. For this measurement, do you mean to the to the outermost edge of the axle seals? All of the diffs I have are assembled. I don't have any apart right now if yo need that dimension from the shaft centerline to the edge of the case minus the side covers. But even that diminension I could approximate for you.
*Centerline of output shafts to rear (service cover)
I not sure what dimension you're looking for here. To rear of the tin cover?.
If these measurements are what I am looking for, would you have a trashed Getrag housing to sell? I would be looking for a bad one first to do fit checks. You are right that the Getrag will not just bolt up to the Riv trans, but I can design and machine some adaptor plates. While I am asking, what spline does the pinion shaft use, 27 like other GM? Thanks.
