SignUp Now!Is the calpack chip a programmable chip like the main chip ?
No. It's really nothing more than a network of resistors that provide default values, when limphome is enabled.
Just to add to this, I always thought it would be nice to have the different calpacks available for different injector sizes. I know that I f I have a glitch that throws the ECM into limp home mode with 72lb injectors I'm not going to get very far.
Don't know anyone who has ever reverse engineered the calpack. I casually looked at it once but didn't get far. In limp mode the engine will barely run with 50's and blow black smoke all the time, and with anything larger it is hard to keep it running. If you do go into limp mode fueling with 50's or bigger get it shut off as soon as you safely can and then change the oil asap as you have just filled it with gasoline.
