Sep 15, 2008 #1 L leehatten turbo rust Joined Jun 23, 2005 Messages 162 I am looking for stock replacement cam lifters push rods and valve. Where can i buy stock replacement
Sep 16, 2008 #3 S SouthernCal GN I come in peace....AK AK Joined Mar 18, 2004 Messages 2,561 I have a 204/214 cam and lifters that were in an engine for about 250 miles, then I went roller.
Sep 16, 2008 #4 L leehatten turbo rust Joined Jun 23, 2005 Messages 162 do i need to change the from the 80 lbs valve spring to the 100lbs also do i need to change the length of the push rods
Sep 16, 2008 #5 4 49-blues Active Member Joined May 30, 2001 Messages 7,628 Sealed power has a similar slightly larged cam than stock- id go with the 204/214.
Sep 16, 2008 #6 S SouthernCal GN I come in peace....AK AK Joined Mar 18, 2004 Messages 2,561 Depends on your goals- the stock ones (new) are fine for stock/mild build applications (11s).
Sep 16, 2008 #7 D dsmith4994 Member Joined May 5, 2004 Messages 653 re: cam I have several used stock cams in good shape for sale if you were looking for used....Dave
Sep 17, 2008 #8 L leehatten turbo rust Joined Jun 23, 2005 Messages 162 well considering we dont have a track here in honolulu there is no need to go fast so stock or mild is all i need
