My cam gearset is probably pretty worn out so I thought that while replacing it I'd put in a new cam. But what cam?
I know this question has been asked a thousand times, but every combo is different so here goes again.
Here's my combo:
Fuel: Walbro GSS340 fuel pump hotwired, 009 injectors (42.5pph). Adjustable fuel pressure regulator, homemade alcohol injection.
Air: K&N 14", LT1 MAF and Translator. RJC powerplate. Both valve cover breathers.
Turbo: Precision TE-44. Adjustable wastegate actuator
Intercooler: Ford Powerstroke Diesel front mount
Cooling: Nick Micale 3-row radiator, high-speed fan switch, Ramchargers dual fan, heater hoses blocked to/from the throttle body. Coolant--distilled water with RMI-25 and rust inhibitor added. 160 degree thermostat.
Engine: New valve springs at 133,000 miles. Engine tie-down. Stock cam, stock heads, stock block, etc.
Exhaust: custom made single shot, Terry Houston 3" downpipe, test pipe with electric cutout.
Trans/Torque Convertor: StageRight Transbrake. Torque convertor lock-up switch. Rebuilt trans with a Precision, 2800 stall torque convertor.
Electronics: Jay Carter 108 octane race chip or 93 octane street chip. Plugs: Autolite 23's @ .035 and Accel 8mm wires.
Suspension: Air bags in the coil springs (10psi right, 5psi left), 4" pinion snubber, boxed lower control arms, rolled the lips on the fenders.
Tires: 275x50x15 BFG Drag Radials mounted on 8" wide aluminum rims.
Differential: Posi. 3.42 gears (stock)
Last time I ran at the track the car ran a 12.3@113. I've added the RJC Powerplate, the THDP, the 2800 stall convertor, the front-mount intercooler and replaced an older Walbro with the one mentioned above since then. Feels strong, but who knows without a time slip?
So, what cam with all that and stock heads? Remember, the car has the vacuum brake conversion.
Keith
Here's my combo:
Keith
