blacknight80
- Dec 26, 2013
hey guys,
I got my car going for the first time this spring and The car reminded me that I have a bad lifter. I am unsure of how many miles have been put on the motor since the lifter failed but I'm guessing the cam may have a bad lobe as a result. It idles rough and my esc pulls timing because of the noise. Can you guys give me some advice on what cam I should go with. The car has little to mods. Stock heads that have been freshened up with a 3 way valve job and its bored over .02. No cat and a cold air intake with a cone, stock turbo and 80 exhaust manifolds and I am unsure of the stall in it.....I'm thinking its stock as well. So it's nothing wild at all.
I read that crower, erson, comp, and edelbrock make cams that will work with a turbo but I could use a little help. I keep hearing bad things about comp but I am impartial. I just want something to help build boost a little quicker and wake it up a bit.
I am planning on modding the oil pump so if I take the timing cover off I figure I might as well do the cam.
