turbov6joe
Signal 1 J-12
- May 22, 2002
What I need to know is if anyone has any idea what would be a tollerable range between cam lobe measurements? I was measuring a Comp Cam and between the lowest and highest measurements I had a difference of .021.
I measured a Lunati cam and the same difference was only .006. I wonder if Lunati and Comp have different ideas of what are acceptable ranges at manufacture??? What's very odd was that the Lunati had an advertised lift of .426.....the lowest measured lift I had was .440 and the highest .446; WTF
The Comp has an advertised lift of .459, the lowest I measured was .454 and the highest .475; WTFx2
The Comp cam has approximately 500 miles and the Lunati prolly 15k.
