SignUp Now!Best on foot brake was 1.7xxWhat ki d of 60fts are you seeing?
He definitely seems light on the spring to me as well.I have an extra set of new 1.65 rockers and shaft assys. But you still need springs INMHO.
TIMINATOR
That's gotta changeBest on foot brake was 1.7xx
That’s the idea behind the changes. Just looking at changing things that will improve the entire combo while I have it apart for new rings, timing chain, trans refresh, etc..That's gotta change
Your leaving a ton of et on the table.
The springs are the easiest to change as stated
Then work the 60ft set the car up to leave correctly.
So 140# springs seem light?He definitely seems light on the spring to me as well.
For your combo, yes. Reread about boost pressure under the intake valve, and exhaust pressure under the exhaust valve. TimmSo 140# springs seem light?
So 160s should set in about 148-150# after break in?…For your combo, yes. Reread about boost pressure under the intake valve, and exhaust pressure under the exhaust valve. Timm
The comps dont seem to lose as much as lesser quality springs do. And besides, they are pretty! And dont forget those shiney polished titanium retainers!So 160s should set in about 148-150# after break in?…
If you want to spin it under boost.So 140# springs seem light?
